TOPIC: '67 80 hp stupid question
'67 80 hp stupid question 11 years 4 months ago #79737
  • Waterwings
  • Thank you received: 100
Ok this is going to be a stupid question, just so you know right off the bat. I completely forgot to take a picture of the positive and negative cables from the battery to the power head and can't for the life of me see where the negative cable should connect. I know the positive connects tot he opposite side of the solenoid, from the starter connection but where exactly is the negative suppose to connect? Painted everything so well can't tell where. Can anyone help an old idiot out?
Re: '67 80 hp stupid question 11 years 4 months ago #79743
It should go to a solid ground on the engine block.
In the following diagram, you'll see a special stud (part #78) that's screwed into the intake transfer port cover of #1 cylinder:
www.marineengine.com/parts/johnson-evinrude-parts.php?year=1967&hp=80&model=V4A-19&manufacturer=Johnson§ion=Powerhead+Group
That's what I remembered it looking like, a 1/4-20 stud with hex for a socket in the middle. The hex tightens up against the cover, like a regular bolt, but you've got the additional threads sticking out.
The diagram also shows a lock washer/star washer. If you use an external star washer on each side of the battery cable "lug", they will dig into the lug and prevent the cable from moving and "unscrewing" itself. OMC uses a lot of star washers on critical connections, and the ones for the battery cable were stainless.
If you can't find the special stud that was used for the negative battery lead, just find a good grounding point within the reach of the cable, with the correct-sized bolt, and lash 'er down. Be sure to clean any paint off the parts you're bolting the cable to, so it'll have a better electrical connection.
HTH............ed
Re:'67 80 hp stupid question 11 years 4 months ago #79763
  • Waterwings
Outstanding, thanks Ed. Yep if it was a snake it have bit me!!!!!!!!!!!!!! Looked all over that darn thing and didn't see it. Went back out and looked where it should have been and found it right away. Part of the reason I missed it the first time was I had a terminal from the internal wiring harness already on there so I didn't see the extra threads sticking out. Painted it too well I guess. ;)
Hopefully I'll be posting some pics soon. Still have to paint the cover but I'll take some shots of the rest.
Thanks again Ed.
Time to create page: 0.256 seconds
We have 10600 guests and one member online
