TOPIC: Trying to remove gearcase...
Trying to remove gearcase... 11 years 2 months ago #82943
  • NepaBob
  • NepaBob's Avatar Topic Author
...and it won't separate from exhaust housing. The gear lube was removed, shift connector disconnected, forward nut and four gearcase screws removed. It is stuck under the forward bolt. I tried to pry it and beat it with no success. It's an 1989 Evinrude 25hp
I'd appreciate any suggestions. Thanks...Bob
Re: Trying to remove gearcase... 11 years 2 months ago #82944
A bit of heat may be required to help release the forward fastener.----Corrosion around the dowel used there?
You also have to slide the nut on the shift rod up to remove the wee black plastic keeper there.-It is split.----There was no need to drain the lube for waterpump work.
Re:Trying to remove gearcase... 11 years 2 months ago #82952
  • NepaBob
Thanks Professor ! After applying heat a few times it loosened up enough to smack off. This is my first attempt at doing the water pump myself and didn't know about the keepers. Of course I dropped and lost one in the grass!
I appreciate your help... Bob
We have 10522 guests and no members online
