TOPIC: Prop Questions
Prop Questions 10 years 8 months ago #90945
Hey guys,
It finally got into the 30s outside yetserday, so I decided to go out and pull some maintenance on my 1962 40hp johnson.I Pulled the lower unit to reseal the gearcase and to also install a new impeller.
Ive never had the prop off this motor before, so i never checked to see what pitch i was actually running. when i looked, i realized that the prop i ran all last year is a michigan wheel prop. There is not a standard pitch stamped into the prop hub, like most others. all that is stamped is , "PJ 30". does anyone know what pitch this prop is?
I have a spare 10 3/8" x 12 prop also. Does anyone know how the michigan prop compares to my spare?
Funny thing is that i only live 20 minutes from the michigan wheel building in grand rapids , MI. I drive by it often. Im thinking about stopping in to see if they can tell me anything about the prop specs.
Thanks!
Scott
Re:Prop Questions 10 years 8 months ago #90947
  • VinTin
  • VinTin's Avatar
I believe the standard prop was 10.375 X 14".
If that motor sees a heavy load you'd want less pitch. PropCo sells a prop for that motor for Pontoon boats.....11" X 9".
Re:Prop Questions 10 years 8 months ago #90960
Hey Scott, here's a link to a Michigan Wheel prop chart you might find helpful;
bluewatermarinesvc.com/pdf/Mi-Wheel.pdf
Re:Prop Questions 10 years 8 months ago #90968
I look it up in my prop book and it is a 10 3/8 by 12 1/2 three blade Aluminum that fits 1951-69 22, 25, 28, 30, 35 & 40 HP
Greg Anderson
Wisconsin
Re:Prop Questions 10 years 8 months ago #91043
Thanks for the info guys. Ill have to try out the 2 props I have and see how they run
Time to create page: 0.273 seconds
We have 10493 guests and no members online
