  • 2
TOPIC: Manually Lowering 115 Outboard
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11437
Loook for the pump in the boat there is a larger knob that screws in and out by hand. One way it will let it down.
Conrad
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11443
  • RB78
  • RB78's Avatar Topic Author
Conrad
This pump?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11446
yes that knob just above the vise grips.
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11469
  • RB78
Thanks. It was all the way to the left. Twisted it fully clockwise and nothing. Do I need to disconnect the hoses next?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11478
try pushing down on the motor the pivots may be rusted last resot breed the hoses.
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11479
No Dave, no breeding hoses here, this is a family web site! :laugh:
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11540
If I recall the tilt release knob on the PT&T pump only allows you to tilt the motor up, not to lower it down??
Is there any possibility of hooking a battery directly to the pump to energize the "down" solenoid? That should be the one with the green wires connected.
Another way to relieve oil out of the trim cylinders would be to remove the 'bleed' screws. Little allen-headed screws that you remove to bleed air out of the system. If you pull the right set of screws the motor's gonna go down. I would think the screws at the bottom of the cyl would do it but if not, the ones at the top (if you can get at them).
HTH........ed
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11553
  • RB78
I'll try that suggestion tonight when I get home. Thanks for the info.
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11554
  • RB78
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11623
  • RB78
HTH........ed
Need to replace the battery. Found the green wire, which is the ground?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11624
  • RB78
HTH........ed
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11625
Black is ground, green for down, and maybe blue or red for up? Can't remember!
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11716
  • RB78
HTH........ed
Got a new battery. Connected the ground & green wire. Heard the pump trying to do something, but motor didn't move. Tried the other wires & nada. I start vacation this Saturday. Will try bleeding then. I have the hoist & stand - just want that motor down and off. Bought a SELOC maintenance book, as well. It kinda-sorta addresses lowering problems ...
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11717
  • RB78
HTH........ed
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11718
  • RB78
Why am I double posting all of a sudden?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11719
  • RB78
HTH........ed
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11725
Does the pump have oil in it? Does your unit have one or two solenoids?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11750
  • Matt
  • Matt's Avatar
the postiion of the motor looks like the locking tab might be in place...on the right side of motor look for a tab on motorside that is resting on the motor mount...flip the around and then try lowering....manually or w/ trim pump....
Matt in Illinois
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11753
  • Doug Reeve
  • Doug Reeve's Avatar
  • Away
  • Thank you received: 31
I downloaded the first pic and lightened it up then zoomed in and it does appear the locking tabs are holding it up. Doug
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11796
  • Matt
  • Matt's Avatar
lets us know and report
Matt in Illinois
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11843
  • RB78
OK. Had to persuade the locking tabs to move, then pry them up. The motor lowered about 2" and stopped. Tried the battery again, and nothing.
It's a on-again, off-again rainy day. Have to go out for a couple of hours, but I'll bleed the 2 lines when I get home.
Short of that doing the trick I'm thinking of connecting up the hoist to the motor, then disconnecting the motor from the trim/tilt and lifting it that way. Definitely not my preferred method, but I may have no other choice.
Comments? Recommendations against?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11844
  • RB78
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11880
  • Matt
  • Matt's Avatar
did you try turning the knob on the pump the other way now and try lowering?
actually can you hear the pump motor running when hooked up?
next step is to carefully crack open the lines and see if you can bleed them out, lowering the motor by hand...
not sure either why your double posting?
Matt in Illinois
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11881
  • RB78
Yes, can hear the motor, and completely forgot about the knob. It's back to its original position - full counter-clockwise. Will try that again tomorrow. Rain prevented me from bleeding the lines today. Thanks, Matt.
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11960
  • RB78
Knob made no difference. Bled the starboard side, but nuts were stripped on the port side. Wound up cutting the line to the port side. It was dry as a bone.
Motor is now down:
Waiting for lift ring to arrive. Hope to have that tomorrow, but have not heard from the shipper.
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11962
Where are you located? I have two lift rings! You should fill out your personal info thing, maybe then somebody close could give you a hand. Good luck!
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11964
  • RB78
I'm in Manchester, NH. Just spoke with the shipper. Ring will be here Wednesday. Their computer system has been down since Thursday. Good thing I called them. 2 rings?
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11966
  • RB78
Profile is updated.
Steve
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11968
Darn Steve! You're more than a full state away.
Re:Manually Lowering 115 Outboard 14 years 4 months ago #11976
  • RB78
At least one from everyone. :cheer:
Re:Manually Lowering 115 Outboard 14 years 4 months ago #12071
  • Matt
  • Matt's Avatar
who did you get the riing from? heartland mfg. near chicago,IL?
wondering they are like 90 minutes from me...i got one from them worked great ended up ordering from them again to turn lifter into a puller for the flywheel...
good luck...you redoing the boat then? motor run?
Matt in Illinois
Re:Manually Lowering 115 Outboard 14 years 4 months ago #12086
  • RB78
No, I ordered the ring from Bob's Machine Co. in Florida. Only place I found on the web when I searched. Great people.
Yes, stringers and flooring is shot. Replacing transom, as well. All of the wiring and the instruments. I have new pedestal seats coming in.
Motor is supposed to have been running. I have my doubts. Flywheel turns, but grudgingly. Very stiff. I have a friend who's brother is a marine mechanic. He is coming by after his vacation to check it out.
I have a thread in iboats (picture heavy) re: the work:
forums.iboats.com/showthread.php?t=411100
Re:Manually Lowering 115 Outboard 14 years 4 months ago #12087
  • RB78
Re:Manually Lowering 115 Outboard 14 years 4 months ago #12088
  • RB78
Re:Manually Lowering 115 Outboard 14 years 4 months ago #12126
  • RB78
Lift ring fits beautifully. Very nice ring. Unfortunately, motor still refuses to lift off. Those iron rods are jammed in against the motor, and the motor prevents the rods from coming out. Catch-22.
Have to think of something for tomorrow ...
Re:Manually Lowering 115 Outboard 14 years 3 months ago #12322
  • RB78
IT'S FINALLY OFF!!!!
Th must have filled those bolt holes with 3M5200. This one was a serious pita to get out.
So it's just hanging around in my garage for the time being.
Need to replace these bolts, as well ...
Very glad to have that off at last. I should have my heat gun this week, and then I'm off and running to remove the bumper ... should be lots of laughs.
Re:Manually Lowering 115 Outboard 14 years 3 months ago #12323
  • RB78
Re:Manually Lowering 115 Outboard 14 years 3 months ago #12324
  • RB78
Re:Manually Lowering 115 Outboard 14 years 3 months ago #12325
  • RB78
Re:Manually Lowering 115 Outboard 14 years 3 months ago #12326
  • RB78
  • 2
Time to create page: 0.318 seconds
We have 4816 guests and one member online
