Continuing the work in the bow of the boat, it was time to install the new foam.
Starting point.
As noted in the previous post, I used a Fein Multimaster with 2" blade to remove the original foam in layers.
The old foam was surprisingly dry.
Once all the foam was removed, the hull and cross member were sanded with 2" rotary disks driven by a pneumatic right-angle die grinder. Additionally, using a 1”-holesaw, I drilled a hole in the cross member where it meets the keel. This is needed for my newly engineered drainpipe.
Using CAD (cardstock aided design), I made a template of the cross member and covered it in two layers of 1708 fiberglass cloth.
I picked up some 1" PVC pipe and cut it to length.
Using a heat gun to warm the PVC pipe I was able to shape it to conform to the keel.
My idea is to have a drain pocket just below the bow eye ring block.
Then, a bed of Polyester Structural Repair Putty was troweled into the keel and the PVC pipe pressed into the putty
I used 2lb floatation foam to fill the cavity. I underestimated the amount needed and ended up purchasing three of these quart kits. Could have saved money by getting a gallon kit up front.
As you can see, my first pour fell far short of need.
Additionally, as you know by now, my best laid plans eventually run afoul.
I meant to plug my newly installed drain tube so foam could not enter it.
Well, it didn't happen, and I accidentally poured some of the liquid foam down the tube.
The tube did a great job of draining it, until the foam started to expand. My new drain tube was now completely plugged.
This was devastatingly frustrating, and I walked away from the project for a couple days.
After taking some time to think, I was not going to dig all the new foam and Polyester Structural Repair Putty out, so I devised a plan to clear the foam out of the pipe. $65 in tooling later along with some modifications, I put together this setup. I cut 36" of drill rod into four pieces and placed couplers on them. I needed to do this because I only had access to drill from the bilge up. The floor only gave me 12 inches of access in the bilge.
Section by section, I was able to push the boring bit from the bilge side of the pipe up to the eye ring block entrance. I worried one of couplers would lose grip, leaving me no choice but to remove everything and start over, but this did not happen. I was then able to use a shop vacuum to suck out all the shavings and retrieve the tooling.
Interesting discovery, the foam did not stick to the walls of the PVC, it just blocked them.
With the tube unblocked, I resumed adding more foam.
Using some cardboard, I created a dam around the top of the drain tube to create a pocket/basin for water to collect.
I covered the dam in box tape, so the foam would not stick to it.
Dam in place and drain tube now plugged, I shaved a few high spots of the previously poured foam with the Fein Multimaster tool.
A quick vacuum left me ready to resume pouring foam.
A couple more pours left me with this.
Using CAD, I created templates of the foamed area, so I could fiberglass it in.
Five layers of tab-in pieces and four layers of floor chop strand glass pieces cut and ready for install.
Using the Fein Multimaster and a 6" random orbital sander, I was able to smooth the foam and shape the ‘drain well’ by the bow eye ring block.
Because the foam is porous, I understood it would absorb an immense amount of polyester laminating resin. So, I spread a thin layer of Polyester Structural Repair Putty over the entire surface. I was extra careful to make it as smooth as possible as I wanted to glass right over it while it was tacky. (no sanding)
The layup went well. A tab-in piece was first placed on the hull next to where the original foam was trimmed back and then overlapped onto the newly installed foam and ran from the drain well to the cross member. Then a layer of glass was placed on the foam, followed by another layer of tab-in pieces until five sets of tab-ins and four foam layers of glass were applied. The layup required large (12-16 oz) resin pours with frantic rolling and brush tapping, but it turned out pretty well! As this is a confined space, my eyes were burning from the curing reaction driving me to wear a full faced respirator.
The final step in this phase was to clean up the transition from the thick original foam on the hull to the newly laid glass. I again used Polyester Structural Repair Putty to fill the void, creating a smooth, watertight joint.
