TOPIC: Westbend
Westbend 7 years 7 months ago #114153
  • 57owens
  • 57owens's Avatar Topic Author
Hi
Need :unsure: some help with my late 50s Westbend 35hp what is missing in the groove on the crankcase, is it a O-ring?
Thanks Carl. [image/]
Re:Westbend 7 years 7 months ago #114158
With no knowledge of your motor I would guess one of two things. Most likely that is the rear main seal. The old school car motors used what looked like a piece of rope which it was somewhat like all be it special made for the job. The other thing would be a thrust washer. That would be on the crank and mate with your groove. Those would be my guesses.
Re:Westbend 7 years 7 months ago #114167
  • 57owens
One more pic :unsure:
Re:Westbend 7 years 7 months ago #114173
  • Away
  • Thank you received: 96
The ebay item id given is invalid, no result has been sentThe slot may have held a snap ring or some other type of retainer to keep the crank bearing in position.
There are some parts manuals on eBay which would help you identify the piece (if any):
Re:Westbend 7 years 7 months ago #114190
  • l98tpi
  • l98tpi's Avatar
My manual for the later Chrysler version of this motor shows nothing in that groove. Little changed in the later motors really. I suspect its just a convenience groove to stop the cutter in while boring the different bores.
Re:Westbend 7 years 6 months ago #114206
  • 57owens
Hi
I have a copy of a 35hp west bend model no 35801 parts list, I have no model no/plate
on my outboard, it has had a hard life, I stared to overhaul this motor over a
year ago and never remember a O-ring or clip, but I just need to know so I can
start to rebuild the motor. Thanks Carl.
Re:Westbend 7 years 6 months ago #114207
  • 57owens
One more pic
Re:Westbend 7 years 6 months ago #114208
  • 57owens
Up date pic
Re:Westbend 7 years 6 months ago #114234
Lookin' good Carl!
Re:Westbend 7 years 6 months ago #114241
Thinking about it some more I was thinking about a main seal but it is a two stroke it doesn't need one.
Re:Westbend 7 years 6 months ago #114653
  • l98tpi
  • l98tpi's Avatar
Yes they do need a seal on each end of the crank and between each cylinder. The crankcase pumps the mixture into the combustion chamber. If any of the seals leak it will run like crap.
Re:Westbend 7 years 6 months ago #115003
my 67 45hp is the same way. nothing goes there, i bet it is in fact just a transition for the machine cutters. it does take a seal, probably 4016-1, same p/n top and bottom
Re:Westbend 7 years 4 months ago #116681
  • l98tpi
  • l98tpi's Avatar
Why the cream white later Chrysler paint and not the blue/white WB scheme?
BTW I agree with that groove being a process artifact.
Time to create page: 0.188 seconds
1955 Winner Plasti Craft
03-23-2023
1958 MFG 15' Boat
1958 MFG 15' Boat
02-17-2023
Chrysler racing outboard
We have 5222 guests and 2 members online
