TOPIC: Fuel Starved
Fuel Starved 6 years 6 months ago #126345
  • Kevchoe
  • Kevchoe's Avatar Topic Author
Hello. I'd appreciate some input. '66 Chrysler 105 hp. Engine is running great. Last weekend it started throttling back after 10 seconds. If I go slow, it's fine. If I speed up it will eventually roll back. I have to pull throttle back and re-engage. The filter looked pretty bad so changed it. Took it out today, sure it would be fine. It wasn't. It maybe runs a few seconds more than it did last week. Maybe 15 seconds. Help. What should I check next?
Re:Fuel Starved 6 years 6 months ago #126372
  • Robby321
  • Robby321's Avatar
  • Thank you received: 10
Loosen the gas cap when it starts to act up. Could be a clogged vent, or maybe tank pick up clogged. Or deteriorated gas lines.
Re: Fuel Starved 6 years 6 months ago #126385
  • Away
  • Thank you received: 96
Could also be a bad fuel pump. If you pump the primer bulb and it runs better, very likely the fuel pump diaphragms are weak and/or there's debris in the pump check valve(s) and that'll effect pumping.
Re:Fuel Starved 6 years 6 months ago #126392
  • Kevchoe
Thx. Getting some ideas. Seems so obvious now. Also, the filter bulb wasn't filling up when running at speed. It was just settling in the bottom 1/4th. I think you're right. Clog upstream somewhere or vent clog. Thx.
Time to create page: 0.140 seconds
1955 Winner Plasti Craft
03-23-2023
1958 MFG 15' Boat
1958 MFG 15' Boat
02-17-2023
Chrysler racing outboard
We have 4911 guests and 3 members online
