TOPIC: RDS 20 wiring question
RDS 20 wiring question 9 years 8 months ago #107245
The wiring diagram I have shows two mag terminals on the ignition switch. The new switch I have has one ign. terminal. Can I connect both wires to the ign. terminal, or do I need a different switch.
Bill
Re: RDS 20 wiring question 9 years 8 months ago #107261
barnickelbill,
Fwiw, you & I are the only two people that I know who actually have a SUPER QUIET that is complete/functional.
IF I remember correctly, you need a different switch.
Re:RDS 20 wiring question 9 years 8 months ago #107264
Yup, you need an ign switch that shorts the mag with the key in the "OFF" position.
Like this one I found on eBay:
That one looks like it's for a dash-mount, others are available with shorter bodies.
Edit: like this one!
HTH...........ed
Re:RDS 20 wiring question 9 years 8 months ago #107268
Thanks guys, off I go shopping again!
Cheers
Bill
Re:RDS 20 wiring question 9 years 4 months ago #112512
Went to install the new switches yesterday, and I still think they're wrong. Has only one mag terminal. Can the other mag wire go to ground, or do I need a switch with two mag terminals?
Bill
Re:RDS 20 wiring question 9 years 4 months ago #112513
Is this the same switch you were looking at Ed/Bill?
www.iboats.com/Sierra-Ignition-Switch/dm/view_id.47123
I need one as well and the ebay listings are gone.
Re:RDS 20 wiring question 9 years 4 months ago #112536
Hi Bill,
Yes, the second magneto wire will go to "ground".
Hi Mark,
I do not think much of the plastic bodied switches, but the brass cased one Bill pictures is nice.
Regards,
Joe
Profile Picture:
Re:RDS 20 wiring question 9 years 4 months ago #112542
Thanks Joe, I was hoping that was the case. The only switch I could find with two mag terminals was the plastic one, which I really didn't want to use.
Cheers
Bill
Time to create page: 0.186 seconds
We have 6828 guests and no members online
