TOPIC: long to short shaft
long to short shaft 9 years 3 months ago #113156
  • frog
  • frog's Avatar Topic Author
  • Thank you received: 3
I am looking at buying a boat with a short transom. and I have a really mint 1967 big twin 40, but it is a long shaft. now my question is what parts do I need to convert it to a short shaft? and what years will work? this is a gear shift motor. and do any of you guys have the parts that are in good condition. thanks frog
Re:long to short shaft 9 years 3 months ago #113167
Frog for that job all you realy need is the shaft. just remove the spacer and change the shaft. well I gess that you need the short shifter rod to. (ive been working in eletromatic to long) good luck Bob
Re: long to short shaft 9 years 3 months ago #113173
Hey Frog, I have the entire lower unit, including shaft and short shifter rod, for an early 60's Evinrude 40. Don't know if it's the same, but I suspect that it is.
I've seen the shifter setup 2 ways, one long rod, and a rod with an extra long brass connector/coupler. If that's yours, then you just need the shorter rod connector and shaft. If not, then you'll need a new shift rod and short connector.
If want the lower unit and short connector, let me know. You can have it for shipping and a little extra. Only problem is I may not be able to get to it for a couple of weeks, so if in a hurry, I'm not your guy.
Let me know, and good luck!
Re:long to short shaft 9 years 3 months ago #113178
  • frog
thanks , . I never had to do this conversion before and are there water tubes that have to be shortened up also. do you know what years are interchangeable . frog
Re:long to short shaft 9 years 3 months ago #113184
Frog I was driving down the road today and had a thought. the water pipes are shorter. iam thinking 5 inches. as for what will fit. iam thinking 1958 35 super quiet up to 1971 40hp? good luck. Bob
Re:long to short shaft 9 years 3 months ago #113192
Oooops, yup, sorry, forgot about those! I'm pretty sure I have those also. The gales only have one, but petty sure the johnnyrudes had 2.
Re:long to short shaft 9 years 3 months ago #113201
Cooling tubes are the easy part, a pipe cutter and ruler will do the trick. 5" off the top end. The lower ends need the bend?
Re:long to short shaft 9 years 3 months ago #113206
yep, as I recall - which is proving to be less reliable as I get older, the bends are at the bottom. :)
Re:long to short shaft 9 years 3 months ago #113209
  • frog
whatsleft, I sent you an e-mail. let me know if you get it as i'm having trouble sending and receiving them. frog
Re:long to short shaft 9 years 3 months ago #113225
Hey Frog,
Got it and responded!
Al T
Time to create page: 0.181 seconds
We have 6871 guests and no members online
