TOPIC: Shipmaster control unit - detent ball
Shipmaster control unit - detent ball 9 years 1 month ago #116362
Bought a used Shipmaster controller. There seems to be a detent ball behind each lever. Has anyone replaced one of these detent balls?
Re:Shipmaster control unit - detent ball 9 years 1 month ago #116364
Pics of the balls would be nice...maybe that should be rephrased.
Are they plastic or steel ball bearing type? If you're having trouble usually a good cleaning of the old grease should suffice.
Re:Shipmaster control unit - detent ball 9 years 1 month ago #116366
It's a hard plastic button with fairly stiff spring action behind it. Gear lever works fine, but the trottle lever works smoothly fir a few movements, the catches and requires a little extra force before it starts moving smoothly again. It also makes a dragging sound and I found a small piece of the plastic button in the housing. I'm wondering if it really needs a detent, the cable has some drag in the sheathing.
Here's a pic of the good lever, with detent in good order.
Re:Shipmaster control unit - detent ball 9 years 1 month ago #116367
Throttle lever and housing with detent notches.
Re:Shipmaster control unit - detent ball 9 years 1 month ago #116368
Time to create page: 0.162 seconds
We have 6697 guests and one member online
