TOPIC: spark plug boots and springs
spark plug boots and springs 6 years 11 months ago #135909
  • curse
  • curse's Avatar Topic Author
I'm getting ready to replace the springs and boots on my 1960 Lark 40. I was thinking about using a heat gun to make the boots more flexible and maybe some dielectric grease for lube.
Does anyone have any tricks or procedures to get the job done?
1960 slickcraft catalina
1963 g-w invader ski-bird
Portage Michigan
spark plug boots and springs 6 years 11 months ago #135915
dielectric grease or a little shot of WD-40 i have used in the past.. but if the rubber is really stiff...a trick I use on air tools for installing the tight rubber boot covers is to soak them in hot water to soften them up..
The following user(s) said Thank You: curse
spark plug boots and springs 6 years 11 months ago #135918
  • curse
Thanks vintagerunner, hot water sounds easier than a heat gun.
Portage Michigan
spark plug boots and springs 6 years 11 months ago #135920
I have had good luck spraying the inside of the boot with silicone spray.
Best,
Larry
spark plug boots and springs 6 years 11 months ago #135938
  • curse
I'll give that a shot too, thanks.
Portage Michigan
spark plug boots and springs 6 years 11 months ago #135971
Spray the inside with silly cone and then push the wire through. Use a plyers to push the pointy end of the spring through the wire and then pull the wire back through until the spring is in position.
spark plug boots and springs 6 years 11 months ago #135981
  • curse
If spring ever shows up I will give it a shot.
Portage Michigan
spark plug boots and springs 6 years 11 months ago #135983
I hear ya.
spark plug boots and springs 6 years 11 months ago #135990
  • curse
Yuck! Looks like possible 60 degrees by next weekend here but todays freezing rain makes me wonder.
Portage Michigan
Time to create page: 0.123 seconds
1968 Glasspar G-3
1968 Glasspar G-3
02-27-2025
1959 Taft Craft 14' Runabout
02-16-2025
02-16-2025
We have 23008 guests and one member online
