TOPIC: 74 evinrude 40 missing off idle??
74 evinrude 40 missing off idle?? 13 years 6 months ago #30638
ive got a norseman 40 that is missing right off idle. ive adjusted the low idle and it idles fairly good and runs real good wide open. It has a dead miss right off idle. Any suggestion how to fix??
Re: 74 evinrude 40 missing off idle?? 13 years 6 months ago #30676
It idles " fairly good "
Not sure what you mean by that???
So do a compression test and check to see that you have spark that will jump a gap of 5/16" or more on both cylinders.
Once that information is known ( proper results )you can look for adjustment issues.
Post the results.
Testing / trouble shooting is the way to go.
Re:74 evinrude 40 missing off idle?? 13 years 6 months ago #30679
If the compression and spark tests come out satisfactorily, you may try increasing (back out) the idle mixture screws 1/4 turn. (Just make note of where they were when you started.) If that helps but doesn't eliminate the problem, repeat above proceedure. When problem is gone, turn screws back in 1/8 turn at a try to maintain maximum economy. (Keeping in mind too much fuel is always better than to little! Lean mixture = trouble eventually.)
Re:74 evinrude 40 missing off idle?? 13 years 6 months ago #30681
Only one carburetor on it and only one idle adjustment screw.
We see so many posts here and elsewhere like " I installed a new switch box and it still runs the same " or " I paid someone $ 500.00 to clean the 3 carburetors and it still runs the same "
So testing and trouble shooting is the way to go.
Time to create page: 0.166 seconds
We have 9284 guests and 2 members online
