TOPIC: 18 Head Gasket Problem
18 Head Gasket Problem 13 years 5 months ago #32753
  • Paul
  • Thank you received: 7
I pulled the head off my 58 Evinrude 18 (had the tell tale sign by skipping at idle until it cooled off a little)and found some of the firing deck on the block eaten away a little bit. Has anyone had any luck by cheating and building it up with anything? Or am I going to have to pull the powerhead and have it milled? Also, can anyone tell me the torque and sequence on the head? Any info will be appreciated.
Re:18 Head Gasket Problem 13 years 5 months ago #32819
Some pix would help to see what you are talking about. As far as tighting sequence. start with to 2 middle one and go to the 2 on each end and then the 2 next to each end. Here are the toquart spec's now look good because some are inch pounds and some are foot pounds.
Mike aka pathfinderz1
Re:18 Head Gasket Problem 13 years 5 months ago #32827
  • Paul
Thanks much.
Time to create page: 0.163 seconds
We have 10039 guests and 2 members online
