TOPIC: converting a 66 starflite 100s ponts ign-elec ign
converting a 66 starflite 100s ponts ign-elec ign 13 years 5 months ago #34961
  • kc8vpp
  • kc8vpp's Avatar Topic Author
i have a 66 starflite 100s that came stock with a points style ignition and i also have a 1968 starflite 100 s with an electronic ignition i dont know if the 68 runs or not but i was wonder how hard or what i would have to do to put the electronic ignition on the 66. or would in not be worth the work that would have to be done.
Re:converting a 66 starflite 100s ponts ign-elec ign 13 years 5 months ago #34995
Points have worked on outboard motor for years so why change it?. If your electronic go out its big bucks to replace.Points and everything else the go with them are cheep or reasonble.
Mike aka pathfinderz1
Re:converting a 66 starflite 100s ponts ign-elec ign 13 years 5 months ago #35052
I have a funny short story... I had a 1957 Evinrude 15 or 18 hp twin (this was 25+ years ago... some details are fuzzy) The thing was a real pain to get started... it would take a 10 or more hard pulls to make it fire. I was determined to tune it up, but i couldnt find points and condenser for it. I was talking to the guys at the local Rent-it-Center, and they handed me a Briggs & Stratton motor electronic conversion kit. A little, inexpensive module that fits under the flywheel and replaces the points and condenser. The module has some proximity sensor in it and senses the points lobe passing. I thought, what the heck and I bought two of them. Put them in (very easy instructions), and reassembled the engine.
I climbed in the boat in the driveway, got the engine all set up, and wound up expecting to pull it hard and fast as I was used to. Half way through the first pull the engine fired up and I flew backwards and cracked my head on the dash... the engine was singing!
I went and shut it down... blinked with amazement (and rubbed the new bump on my head)... sat down next to the motor and gave it a whimpy limp-wristed pull, and it fired right up again.
I had that motor for several more years, and it always started like that... every time... even after sitting for long periods... at the most, two light pulls.
Whacky as it sounds, it was the easiest starting engine I've ever owned.
Bandit - 1959 Glasspar G3
Re:converting a 66 starflite 100s ponts ign-elec ign 13 years 5 months ago #35152
  • kc8vpp
do you have any idea how to find something like that for my engine? because that sounds like it would be amazing!
Re:converting a 66 starflite 100s ponts ign-elec ign 13 years 5 months ago #35233
Time to create page: 0.170 seconds
We have 7222 guests and no members online
