TOPIC: Anyone Know the Pitch on a Michigan Wheel Prop?
Anyone Know the Pitch on a Michigan Wheel Prop? 13 years 2 months ago #45117
Found a Michigan Wheel bronze prop that would fit my '66 Starflite 100.
Number PR 104
All I want is a general use prop. If it's close to something that would run the motor in it's power band, I'm good. And I'll never forget the bronze prop all shined up on my Dad's Mercury 75 horse dockbuster, so there is some nostalgia with the bronze.
Re:Anyone Know the Pitch on a Michigan Wheel Prop? 13 years 2 months ago #45134
Prop numbers? Most Michigan props I've seen have a number stamped into the hub... Without that, it's just a guess...
Re:Anyone Know the Pitch on a Michigan Wheel Prop? 13 years 2 months ago #45139
You better have a good way to tighten the bronze down so there is no slack in it or you will share prop pins just going from forward to revirse. I know i shared 2 in 2 weeks.
Mike aka the pirate
Re:Anyone Know the Pitch on a Michigan Wheel Prop? 13 years 2 months ago #45197
I contacted the seller, I should have them in a day or two.
pathfinderz1 wrote:
You better have a good way to tighten the bronze down so there is no slack ...
You mean play on the prop shaft (loose shear pin)? My aluminum is tight but I guess that doesn't mean the bronze would be.
Re:Anyone Know the Pitch on a Michigan Wheel Prop? 13 years 2 months ago #45214
Chinewalker wrote:
Prop numbers? ...
PR 104
We have 7758 guests and one member online
