TOPIC: Need Help old outboard
Need Help old outboard 14 years 5 months ago #11783
hey guys,
i need some help. this motor came with a boat i just bought, and it runs, but i need to adjust the knobs on the back to keep it running. i think its a 1958 sea king. model# GG8985A
Serial# 85X723905. is that right? anyway i can't find any info on it. what are the knobs for?
thanks!!
Re: Need Help old outboard 14 years 5 months ago #11790
Probably best to post this on the JEGO board here and at www.aomci.net as well.
Re:Need Help old outboard 14 years 5 months ago #11791
Try putting 1958 sea king model GG8985A in google and see what happens. Doesn't bring up a lot, but plenty to get you going.
Re:Need Help old outboard 14 years 5 months ago #11799
Sea King GG8985A is a 1958 Gale outboard motor, rated at 25 HP.
Here's the reference I used:
www.antiqueoutboardwiki.com/wikka.php?wakka=GaleModels
Re:Need Help old outboard 14 years 5 months ago #11803
Are the knobs moving on their own? If so, they have a packing nut at the base of the needle shaft that might need to be tightened a bit. The knobs should move snugly, but not too snug that you can't adjust them.
The knobs are on the ends of the needle valves. Upper is the slow speed adjustment - usually start at about 1.5 turns from closed. Lower is high speed adjustment - usually start at 1 turn from closed. Adjust from there - usually inwards, until the motor starts to lose power or sneeze, then back out about 1/8 turn. Do the high speed one first.
Re:Need Help old outboard 14 years 5 months ago #11811
k916,just for your future reference,gale went out of bussiness and quit making motors in 1963,but most of their parts are johnson/evinrude,so you may still be able to find parts that will work on your motor,john
Re:Need Help old outboard 14 years 5 months ago #11822
For the best info on you motor go over to AOMCI heres the Link
www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=askamember
So of the guys on there have been working on these motors all their lifes
They can give you info on were to get part and all the spec's
Any old motor like that if it has been sitting for a year or more you will want to replace the impeller and drain the lower unit and put in fresh 80wt oil in. I have about 40 or so of these old motors and that is were I go for info. They will tell you the plug settings and points settings. How to adjust the carb and anything else you might need to know and then some.
Mike aka pathfinderz1
Time to create page: 0.173 seconds
We have 14541 guests and no members online
