TOPIC: Help with part name!
Help with part name! 4 years 7 months ago #142282
1961 Larson Lalpline 166
What is the part that holds the rub rail to the boat. It appears to be aluminum and sandwiches the top and bottom parts of the hull together.
Help with part name! 4 years 7 months ago #142284
That would still be the rubrail. That's basically a two piece rubrail, it's just aluminum and rubber vice rubber and rubber. Check tacomarine.com and wefco.com
The following user(s) said Thank You: bora12
Help with part name! 4 years 7 months ago #142286
  • Doug Reeve
  • Doug Reeve's Avatar
  • Away
  • Thank you received: 31
It might not make any difference to the rub rail, but are you sure it's a 1961? I have a pdf of the 1961 brochure and I don't see a model 166 in it.
Help with part name! 4 years 7 months ago #142287
Yes you are correct, I miss remembered the year, it is a 1967 Larson 166. I had to go look at my paperwork... good eye!
Help with part name! 4 years 7 months ago #142288
Waterwings wrote: That would still be the rubrail. That's basically a two piece rubrail, it's just aluminum and rubber vice rubber and rubber. Check tacomarine.com and wefco.com
on tacomarine's website I can find the replacement rubber part, but not a metal one with the profile like the one on my boat. Any idea on other places to look? Luckily the metal piece is in good shape, just needs polishing, I just need the rubber part.
Help with part name! 4 years 7 months ago #142297
Check wefco.com
Help with part name! 4 years 7 months ago #142301
Good that you can save the aluminum. This stuff will make it look better than new.
Help with part name! 4 years 7 months ago #142310
i got mine from rubrails .com exact match too. got bent in transit mo#$%^& ^&*#$%^ but im ok now.
billy
Time to create page: 0.182 seconds
We have 9575 guests and one member online
