TOPIC: Mark 35a Lower unit reinstall, HELP?
Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10624
Over a year ago I removed the lower unit of my Mark 35a.
Changed the waterpump. Went to reinstall and only could get it to go in reverse. Can anyone tell me where I went wrong and how to get this back to where I need it? The manual is not very descript when it comes to the shaft and "clutch?" piece.
Thanks for any help.
Chet
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10626
set your shift lever into forward gear , turn the shift shaft on the lower till your into forward gear.....now as you insert the lower into position ...watch the water tube to be certain it will line up correctly.....you may need to rotate/rock the flywheel as you push upwards on the lower to allow the shift shaft and or drive shaft splines to line up
some like neutral some prefer forward gear...I prefer forward as neutral is too easy to rotate off a tooth...then you get only 1 gear forward or reverse as you are experiencing....at least with using the forward gear less chance rotating off a tooth
be patient and vigilant you will get it...even doing many of these its still tricky on some motors depending how well things line up how easy they shift gears etc etc etc
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10629
Thanks, I'l give it a shot this afternoon.
Which way does the shaft rotate for forward?
Clockwise or counter clockwise?
Thanks again
Chet
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10638
counter till it goes into neutral then back to foward.
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10669
Ok, after turning the shaft counterclockwise until it stopped, then back one click (in gear) the lower unit will not go up. it comes within about 5/8 to 3/4 of an inch. However if I have someone move the handle tword neutral on the controls it pops right up. The problem is it still only has reverse and neutral. Forward is impossible to move the lever into. Am I doing something wrong?
Thanks in advance for all of your help.
Chet
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10730
Anyone?
Should I have to do anything with the linkage? :unsure:
Do I need to jump up and down on one foot, pat my head and rub my belly then kick the boat, wiggle the shifter and it goes in? :unsure:
Any tricks?
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10745
take a long screw driver and hammer and tap the shift shaft down it is under the bottom carb.
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10753
Thanks Dave, I'll try it.
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10756
That did it! Thanks again for all of your help!
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10761
great glad it worked. i worked at Grubb's marine in the 60's learned alot during that time.
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10762
Re:Mark 35a Lower unit reinstall, HELP? 14 years 4 months ago #10769
Taking it out on Saturday. Hope all works well. I changed all the fuel lines, rebuilt the fuel pump and carbs, also changed the points. Last time it went out it would not RPM, so it just wouldn't plane. I followed the last suggestions from the previous Mercury board that moved over here and you guys haven't failed me yet.
Thanks again!!
Time to create page: 0.192 seconds
We have 5020 guests and no members online
