TOPIC: help regarding fuel oil mix 196? merc 6hp twin
help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114960
Hi folks. I broke the choke knob on my mariner which runs 50/1 just like my big merc so they run off the same fuel tank. While the mariner is down, there will be a white case 6hp twin merc in its place.
The 1960s merc 60 runs on 40/1. However,, its been said that in dirt bikes anyway,, with the newer high tech lubricants and detergents,, that its safe to run thinner mixtures.
Looking for opinions: Can I safely run the merc 60 on the same 50/1 fuel mix as the big merc 800? Cabellas premium 2 stroke oil with all the fancy additives is whats in the gas.
mercury 60 6hp twin serial # 1526973.
Re: help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114963
Yes, although some may argue with me. Most any Merc with needle bearings (which is nearly all of them) can run 50:1 safely.
Re: help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114965
I agree with ggreggc.
It will be fine at 50:1 with a TC-W3 oil.
Throw a little Sea Foam in the mix too.
doc
Re: help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114967
Agreed . merc recommended there 50-1 oil when the brought it out.
Re: help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114971
Well, I knew the Dr. and Dave wouldn't argue with me, but I thought maybe someone would, guess not.
Re: help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114972
Use good oil at 50:1 and all will be well.
Re:help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #114973
Thanks! Sure makes it less complicated.
Re:help regarding fuel oil mix 196? merc 6hp twin 9 years 2 months ago #115265
Ive been running this on 50/1 no problems. Plenty smoke, and idles down real clean,, unlike my mariner....
Time to create page: 0.184 seconds
We have 8606 guests and no members online
