TOPIC: Replacing the bearing on Magneto drive. First one
Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118147
  • Hugh Long
  • Hugh Long's Avatar Topic Author
I have two mag drives that need the bearings replaced. I notice that with the pulley off, the shaft will tap down easy, but what do I remove to get to the bearing? Can't find any info in my books and I don't want to damage anything.
Re: Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118148
the cap has a lock washer with 2 locking tabs in the little grooves. must clean them out to see. bend them down and unscrew the cap. then tap the bearing out from the bottom to the top. while you are there disassemble the tower and clean and grease.
note this is only for the 56 and later only. for the early ones call me.
1 914 310 7086.
Re:Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118149
Hugh,
Not sure if this helps but here is a Kiekhaefer mag dis assembled.
I'm not able to get a larger pic so you can see numbers on bearings this is a mag for a Mark 55e. I was unable to see a few numbers on the bearings but here is what I have
top bearing Drive End FAFNIR 9103PPC1
Middle Opposite Drive ?6002XEZ
Bottom Magneto Pilot FAFNIR S5KDD
Travis
www.liquidassetsonline.org , 63\'PowerCat14-C w/twin64\'650\'s,14\'Glen-L Zip w/Mark58E,58\'TeeNee,
Mark55AE,Mark55E,PairMark58E\\\'s,Mark58AE,Mark78AEL, 6-7RBM\'s.Keep EM\' Alive! Always looking to add to collection.
Re:Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118157
  • Hugh Long
O K, I will give it a go tomorrow. Thanks for the tip Dave, and the photo pondrocket.
Hugh
Re:Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118167
  • Hugh Long
Easy money, all apart and cleaned, ordered brgs.
Re:Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118175
Hugh,
Were you able to get the numbers off old bearings ?
Travis
Re:Replacing the bearing on Magneto drive. First one 8 years 11 months ago #118188
  • Hugh Long
Yes I was. It is Fafnir S5KDD. Price's went form $5 to $40. I took the $5 ones :laugh: I just need one of the drives now but will do all three and have two ready spares in stock. Just another one of those things best done when things are apart.
Hugh
Time to create page: 0.174 seconds
We have 7293 guests and no members online
