TOPIC: 1977 Mercury 1150 Prop Shaft Seals Question
1977 Mercury 1150 Prop Shaft Seals Question 7 years 5 months ago #132097
I am replacing the prop shaft seals on my 1977 Mercury 1150. I am about to install the new seals and have a question.
The bearing carrier surface where the outer metal rim of the oil seal sits is scratched. What should I put on the outside of the metal oil seal surface to make sure the scratches are sealed? I was going to use Loctite Blue 242 but thought maybe something else would seal the mating surface of the carrier/seal better. The manual calls for Loctite A but I have never heard of that.
Thank you,
Kevin
1977 Mercury 1150 Prop Shaft Seals Question 7 years 5 months ago #132098
1977 Mercury 1150 Prop Shaft Seals Question 7 years 5 months ago #132115
Ed,
Thank you for the information. I'll give it a try.
Do you have any experience with removing seals installed with Loctite 609?
Kevin
1977 Mercury 1150 Prop Shaft Seals Question 7 years 5 months ago #132125
Heat is your friend when trying to remove fasteners or seals installed with loctite.. Careful use of a propane torch or a heat gun will help weaken the "death grip" of red loctite and ease your removal efforts..
CC-John
1973 Century Resorter 16, 225HP Chrysler LM318
1978 Chris Craft 251 Catalina Express, 330HP Pleasurecraft 350 (383 Stroker)
1977 Mercury 1150 Prop Shaft Seals Question 7 years 5 months ago #132145
The Locktite Retaining Compound applies green. Goes on after you install the bearing or seal. Thin, it works into all the gaps around the parts, and dries as a brittle, opaque green. to remove, just break it with a soft blow from a hammer.
Will
1977 Mercury 1150 Prop Shaft Seals Question 7 years 5 months ago #132148
Thank you all for the information.
We have 5505 guests and no members online
