TOPIC: Problems with a Merc 1150
Problems with a Merc 1150 4 years 6 months ago #142840
  • All Dunn II
  • All Dunn II's Avatar Topic Author
  • Thank you received: 14
I have a 1977 Merc 1150 with a problem. It starts decent but idles a little rough. After running it for a while and it warms up, it develops an intermittent high speed miss. Then, when I idle down it will kill like is flooding out. It will start right back up but still idles like it flooding and kills. After it sits for a while and cools down, it goes through the same routine. I replaced the float in the center carb after noticing that it seemed to be dumping gas out of the front when it was acting up. I could force gas out by pumping the primer bulb. The new float seems to have taken care of the problem when I pump the bulb, but it still runs the same. Any ideas?
Bill
Problems with a Merc 1150 4 years 6 months ago #142843
Hey Bill, I got lots of ideas but none concerning Mercs. The older OMC's used to do what you are describing and it was really touchy adjusting the "fast idle, slow idle" needle. I'm sure the Merc doesn't have those. The first thing I would try before throwing money at it would be to get it running somewhat and spray SeaFoam directly in the carbs. Or if you can run some through the gas. If it doesn't help then maybe you got some ethanol damage or a fuel filter issue.
IMHO
Problems with a Merc 1150 4 years 6 months ago #142850
  • All Dunn II
I run Sea Foam through the gas on occasion and only run Premium with no ethynol. Played with the low speed jets a little with no change. Sorry to here about your last run, but like Clint Eastwood said..... And with the big water you go on, it is better quit before it is too late. You can still enjoy boating without owning one - like by passing on your knowledge and going to the shows that you enjoy.
Bill
Problems with a Merc 1150 4 years 5 months ago #142857
Is this an ADI motor (six separate coils, no distributor)? If so, common ADI issues are cracked coils and bad stators. Stator problems usually start out as heat-related and typically lead to total failure. If the coil is bad enough, you can hear arcing as the spark snaps to ground. Any coil with visible cracks anywhere should be tossed.
If this is a distributor model, "trash" in the cap can cause poor running. In that case, pull the cap, flush with carb cleaner, make sure the spring-loaded center carbon contact is free to move, and reassemble.
You can inspect the coils for cracks, and also take resistance readings on the stator windings. If the stator winding resistance is out-of-spec or changes radically when measured cold then on a fully-warmed engine, the stator is likely shot. I've attached a chart showing the proper resistance values.
HTH...........ed
Problems with a Merc 1150 4 years 5 months ago #142859
  • All Dunn II
Thanks Ed, This is a distributor motor with 1 coil. I just pulled the cap this afternoon and cleaned it out. Not much in there, but it had a little corrosion on the contacts so I carefully cleaned them with some fine emery cloth. The carbon contact seemed free and moved easily. I then pulled the fuel pump apart and replaced the diaphragm and gaskets. The diaphragm seemed rather stiff. I replaced the stator last year but I will check what I can. I will check for any other cracks, ect in the ignition system and hopefully be able to give it a try tomorrow. Thanks for help and I will keep you all informed on the progress.
Bill
Problems with a Merc 1150 4 years 5 months ago #142860
Have also seen where the spark plug wires get "leaky" and arc-over. If you run it in the dark, and it lights up like a Christmas tree, that's a problem!
Check the plug wire boots for cracks. The high-voltage CDI ignition can arc from the top of the plug thru a deteriorated boot, all the way to the installed cowling "wrap".
Pull the plugs after running and see if any one plug is unusually clean, or dirty. If all the plugs look pretty much identical, that's a good thing. Any water droplets found on a plug is a Bad Thing!
Problems with a Merc 1150 4 years 5 months ago #142866
  • All Dunn II
I pulled the plugs this afternoon. They were all the same - a little on the wet side but the same. But the last time I ran it was when it seemed to want to flood out. I will pull it out of the garage tomorrow and start it up on the "muffs" and see if it is running any better. If it is, I will haul it up to the cottage and run it on the river for a real test run. I will take the cowl off and run it in the dark just out of curiosity.
Bill
Problems with a Merc 1150 4 years 5 months ago #142887
  • All Dunn II
Well, it starts and idles better than it has for a while. As soon as I pulled away from the dock and pushed the throttle forward, it started acting up. It was running like it was before, including flooding out when I idled it down. I pulled off the cowl and got it started again and gas was running out of the front of the middle carb. Looks like I will be pulling that one off and tearing it apart and rebuilding it.
Bill
Problems with a Merc 1150 4 years 5 months ago #142888
might as well do all 3 carbs
Problems with a Merc 1150 4 years 5 months ago #142894
Check the floats, Merc came out with improved carb floats and it might not be a bad idea to upgrade all the carbs. Also check the fuel inlet needles for any issues.
www.marineengine.com/newparts/part_details.php?pnum=SIE18-7208
Problems with a Merc 1150 4 years 5 months ago #142895
If you are still using a simple (3) post rectifier,...Check your output to the battery voltage.
If it is working itself up around 17 vdc,...Based on your problem description,...Consider putting a v6 regulator with a built-in rectifier on the beast in place of the simple, unregulated rectifier.
There are lots of used ones on eBay, and I have had really good luck with them. Much cheaper than new, and rarely fail.
doc
Problems with a Merc 1150 4 years 5 months ago #142901
  • All Dunn II
I have a Garman depth finder on the boat and the highest that shows for voltage is about 12.5 volts at the battery while running. I have already replaced the float on that carb and that took care of the problem of being able to pump gas through it with the primer bulb. I will be pulling it apart when the kits get here later this week.
Bill
Problems with a Merc 1150 4 years 5 months ago #142916
You should be seeing more voltage.
Ohms test your rectifier.
doc
Problems with a Merc 1150 4 years 5 months ago #142917
Rectifier test.
Problems with a Merc 1150 2 years 5 months ago #146836
  • All Dunn II
Old thread-still same problem. Had the carbs rebuilt and replaced the regulator / rectifier with the one suggested by the good Dr Frankenmerc. It will start and run on fast idle but when I pull back on the idle it starts to break up and dies. Pull up on the fast idle and it strarts right back up. I checked the coil. If I go from the wire to the distrbutor to the positive (where the green wire from the switch box goes) I get .68 ohms. If I go from the positive to ground I get nothing. When I pull the plugs they all are wet. Is it a bad coil?
Bill
Problems with a Merc 1150 2 years 5 months ago #146841
Hey Bill,
Does that 1150 have the crankcase bleed check valves on cylinders 2 & 4?
Terry
Problems with a Merc 1150 2 years 5 months ago #146846
  • All Dunn II
Not that I know of. It is a 1977 model and I guess it is one of the last years with a distributor and a single coil. I ordered a coil and I will find out if that is the problem.
I am still enjoying my Spotted Cows, just doing it on shore or in other people's boats this summer. That is until I get my problem solved!!
Bill
Problems with a Merc 1150 2 years 5 months ago #146847
Hey Bill,
Looks like your motor has the bleed check valves similar to the 800.
parts #25-30
www.marineengine.com/parts/mercury-outboard-parts/1150-115/7112248-thru-7131212-can/cylinder-block-and-crankcase-assembly
On two occasions I have had a valve fail and the motor ran much like you are describing.
Once in Kentucky on the Cumberland River and years later on Geneva Lake and both times had to get towed back to port.
They are a bit of a challenge to get to but easy to check for functionality.
Had a few Cows up in Minocqua last month and planning to quaff some again at Tomahawk in August.
Terry
Problems with a Merc 1150 2 years 5 months ago #146848
  • All Dunn II
Isn't Wisconsin wonderful! I'll check tomorrow, but I have the newer style fuel pump so I don't know if it still has the check valves.
Bill
Problems with a Merc 1150 2 years 5 months ago #146894
  • All Dunn II
I replaced the coil and it seems to have taken care of the problem. It hasn't run this good in quite a while. Had a few Spotted Cows while cruising this weekend and all seemed well. And now that I cursed it, back to the Spotted Cow!!
Time to create page: 0.249 seconds
WANTED 1962 BUEHLER STERNPOLE
We have 3534 guests and no members online
