TOPIC: 115 Mariner lower unit oil capacity?
115 Mariner lower unit oil capacity? 13 years 9 months ago #26264
Getting ready to do my first change, how much oil goes in there? I've seen the small tubes of lube, how many does it take to fill the lower unit on my 1980 115hp inline 6?
Thanks in advance,
Scotty
Re:115 Mariner lower unit oil capacity? 13 years 9 months ago #26265
Found it, 21 Ounces according to my "repairmanuals4u" digital copy.
Re:115 Mariner lower unit oil capacity? 13 years 9 months ago #26294
Usually when I drain the oil I buy one of those 1 quart containers and it will get it full again.
Take the bottom drain plug out, then take the vent out on top near the flush plug.
Now squeeze the quart into the bottom hole until it comes out the top vent. You have to squeeze pretty hard at the end and kinda fold the bottle over.
Trick is when it comes out the top, dont let go of the bottle to put the plug in. The bottle will suck the oil back out if you let go.
Conrad
Re:115 Mariner lower unit oil capacity? 13 years 9 months ago #26316
I get it in theory but what keeps the oil from just leaking right back out when you remove the bottle? It is vacuum that keeps it in while you (quickly) reinstall the drain plug?
Re:115 Mariner lower unit oil capacity? 13 years 9 months ago #26345
That's the theory, although a little will leak out before you can get the plug in, my experience. You install the vent plug first while still holding/squeazing the fill bottle in the fill/drain hole, and just be as quick as you can be when putting the bottom plug back in.
There are several quality lube mfg's. that offer the quart bottle with the hand pump, or you can buy the pump separately. IMO, it's the best $7.xx I ever spent. It makes it so much easier, and much less messy. Just my two cents...... ;)
Re:115 Mariner lower unit oil capacity? 13 years 9 months ago #26473
Hear hear :laugh: :laugh:
Time to create page: 0.169 seconds
We have 5168 guests and one member online
