TOPIC: HELP!!!
HELP!!! 13 years 6 months ago #31817
  • joenawlins
  • joenawlins's Avatar Topic Author
Trying to remove l/u on my 58A and it's not coming off. removed 2 nuts on sides and 1 by intake. No bolt or allen bolt in rear. I have it in neutral and it's dropped 1/4 to 1/2" and no further. Tapped with board and still not coming off.
Re:HELP!!! 13 years 6 months ago #31819
if you have dropped it 1/2 you have all the boltsout so cut some wood wedges and work it out
Re:HELP!!! 13 years 6 months ago #31820
  • joenawlins
Will try, thx
Re:HELP!!! 13 years 6 months ago #31823
  • joenawlins
OK that didn't work. It seems the aft end wants to come out but the fwd end doesn't. Also looking from aft the right bolt has a screw just forward of that which isn't there on my 78. its not the flush, drain or vent scew.
Re:HELP!!! 13 years 6 months ago #31824
sounds like the shift rod is rusted in place, its in the forward part of the leg
can you see enough of it to squirt penetrating oil in there
Re:HELP!!! 13 years 6 months ago #31826
  • joenawlins
I can try that. does it matter if it's in gear or not??
Re:HELP!!! 13 years 6 months ago #31827
NO!
Re:HELP!!! 13 years 6 months ago #31828
the way that shift rod is setup male/female ends it would work best if you turned the motor up on end so the penetrating oil runs into the coupling part of the shift rod
patients
Re:HELP!!! 13 years 6 months ago #31830
  • joenawlins
I can get it to about 90 on the stand. but there will be no lifting and placing on head!!!!! LOL Getting on stand about killed me.
Re:HELP!!! 13 years 6 months ago #31844
heat the coupling and it will come off did it many times back when i worked at Grubbs marine 60's 70's
Re:HELP!!! 13 years 6 months ago #31849
  • joenawlins
where is the coupler? In the mid sec? Thx, Joe
Re:HELP!!! 13 years 6 months ago #31852
I have a couple apart now Ill get some pics for you shortly
Re:HELP!!! 13 years 6 months ago #31853
  • joenawlins
cool
Re:HELP!!! 13 years 6 months ago #31856
Joe
first pic shows the top and bottom shift rods coupled together as it lokks if inside the DSH "drive shaft housing"
next pic shows the 2 reverse lockout cams the bottom one is splined and the one you will be able to see and need to heat if you cant see the shift rod
last pic shows the splined bottom shift rod....while were here....if you have a problem with your motor not locking in reverse in kicking up
for a quick fix that works well place a stainless washer where shown in the pic, this will increase the travel of the lock out rod and give you positive engagement
Re:HELP!!! 13 years 6 months ago #31869
get to the coupling by aiming the flame down thru the opening in the front of the midsection.
Re:HELP!!! 13 years 6 months ago #31870
good one
Re:HELP!!! 13 years 6 months ago #31883
  • joenawlins
Thx guys, I don't have a torch, which is probably a good thing, but it would come in handy. I'm going to get back at it later today. Have to run errands and hopefully take my Owens to my merc guy and see what's going on with that and get more paint and finish the Invader bottom.
Re:HELP!!! 13 years 6 months ago #31901
If you're gonna spend time on old Mercs you MUST have a propane torch in your toolbox! Mercury was real big on press fit bearings, covers, caps, etc. Heat helps all!!
Re:HELP!!! 13 years 6 months ago #31919
  • joenawlins
You can't use those little bottle ones, can you?
Been running around all day. Went to see my upholstery guy to see if he could match my paint. Then off to west marine to pick up a few things, then Lowes for sand paper and some mix buckets and finally went to tractor supply for another chain fall. Talked to my merc guy and going to drag it over there fri. Then of course I just get home a few minutes ago and get comfortable only to realize I forgot penetrating oil. Oh yea I also went to the Habitat re-store and picked up a couple of wall cabinets to hang in the garage. Hell I'm worn out thinkin' about it!!!
Re:HELP!!! 13 years 6 months ago #31967
  • joenawlins
OK Went out and soaked it and no budging. Got one of those burnomatics and heated the cams from the gap and shot heat down top of mid, more penetrating spray. Beat it with 2X6 and then impact chiseled the cams, no luck. Tried to pull power head and same thing, hanging up on shift rod,,, I'm ready fo BFH and chisel or cutting wheel on rod at top of mid,, Gave it up and put another coat on the bottom of boat and now chillin in the ac
Re:HELP!!! 13 years 6 months ago #31971
you can see by the pics the penetrating oil will go in the coupling best if upside down
right side up it wont get in where needed,unless you have clear access to it and can shoot fluid under pressure
Re:HELP!!! 13 years 6 months ago #31978
  • joenawlins
Got the power head off and soaked and beat some more and soaking again Cracked the fin but nephew in law is a welder and teaches at a local comm coll so will have him fix that. How do I get the shift arms out of lower cowl?
Re:HELP!!! 13 years 6 months ago #31986
lift straight up, it will slide out, but not till you break the rust on the coupling down below
Re:HELP!!! 13 years 6 months ago #32004
  • joenawlins
I got it upside down and went through the soaking and heating and pounding to no avail. Next I see hacksaw cutting it off at the top of mid.....
Re:HELP!!! 13 years 6 months ago #32035
  • joenawlins
OK soaked all night and not budging, can I cut it where it comes out the mid and just get another shift rod?? Thx, Joe
Re:HELP!!! 13 years 6 months ago #32052
  • joenawlins
It's a gone pecan!!! Just hacksawed it and plumped right out seems to be the lock out rod to keep from jumping and the other one is the one that goes to the lower cowl, That's still stuck in mid, might have to cut it too to get the shifter out from the cowl.
Re:HELP!!! 13 years 6 months ago #32328
Oh dear. You have cut the shift shaft off where it exits the L/U, I am fairly certain you will have to strip the L/U down now to replace it.
Re:HELP!!! 13 years 6 months ago #32329
call me if you have a problem with the lower shaft instalation. 1 914 310 7086.Dave.
Re:HELP!!! 13 years 6 months ago #32330
no worries joe it can be done without teardown & your upper shaft is in the mail
Re:HELP!!! 13 years 6 months ago #32386
Ah good, sorry about the bum steer, didn't realise.
Time to create page: 0.295 seconds
We have 5544 guests and no members online
