TOPIC: Mark 58AE water pump inlet
Mark 58AE water pump inlet 12 years 10 months ago #53798
Look past the crappy appearance, in the process of stripping the paint. Is there supposed to be some type of screen over the hole for the water inlet. The po had what looked like a shower drain stuck on with silly cone.
Re:Mark 58AE water pump inlet 12 years 10 months ago #53802
Cal thats the Mercury strainer :lol:
Re:Mark 58AE water pump inlet 12 years 10 months ago #53825
  • tim_c
That probably was the original strainer although it should have a tab that anchors under the nut nearby. or has tabs that get bent over from the inside
Re:Mark 58AE water pump inlet 12 years 10 months ago #53846
Is this a joke you guys are playing on me? I'll use it but thinking of another way to attach it. Maybe tapping a small hole in the area somewhere and putting in a short screw.
Re:Mark 58AE water pump inlet 12 years 10 months ago #53850
Nope, they're telling the truth! It was originally held in place by tabs. You'll see the slots for the tabs once you clean up the area around the hole...
- Scott
Re:Mark 58AE water pump inlet 12 years 10 months ago #53867
  • stashm2
  • stashm2's Avatar
Here is my Mark 35A water pick up/ screen held on with two tabs that are twisted to tighten up top.
Re:Mark 58AE water pump inlet 12 years 10 months ago #53938
You're right, found the slots. The tabs are missing from the shower drain. Are they still available? I'll check ebay.
Re:Mark 58AE water pump inlet 12 years 10 months ago #53942
Cal
I will check my junk pile I maybe able to scrounge one up
Re:Mark 58AE water pump inlet 12 years 10 months ago #53952
  • tim_c
If no one else can find you one I know I have a few. Actually have 8 or 10 new ones.
Tim
Re:Mark 58AE water pump inlet 12 years 10 months ago #53953
Sounds good either of you pm me and we can work out arrangements.
Cal
Re:Mark 58AE water pump inlet 12 years 10 months ago #53955
Cal
I found one but it has a tab about to break off, go for the new one
Time to create page: 0.194 seconds
We have 6743 guests and one member online
