TOPIC: Mercury '60's 400 & 500 fuel mix opinion
Mercury '60's 400 & 500 fuel mix opinion 12 years 6 months ago #60477
  • Hugh Long
  • Hugh Long's Avatar Topic Author
I would like to know what's the best fuel ratio on running these older engines. When I first fired them up ( sitting for long time ) I ran 24:1. I know 50:1 is indicated but what do those of you with more experience than I have recommend. I want them to last and don't intend to hammer them (much)or pull skiers, just cruise.
Re:Mercury '60's 400 & 500 fuel mix opinion 12 years 6 months ago #60487
The oils have improved alot since these motors were new. My '63 Merc 850 has been run at 50:1 since about 1970. I, along with the previous owner, have always used Mercury oil. The motor still runs great. As long as you use a good brand of oil it will be fine (with alot less smoke and fouled plugs).
Bill
Re:Mercury '60's 400 & 500 fuel mix opinion 12 years 6 months ago #60518
when mercury cane out with 50-1 oil it was recomended it for all mercs with full jewled all bearing motors which yours are. i use it at 40-1 for safty MHO.
Re:Mercury '60's 400 & 500 fuel mix opinion 12 years 6 months ago #60543
I agree. I always try to error on the oil- heavy side. I run 12 gallon tanks, and usually put about 11.5 gallons to a quart of oil. You definitely don't want to run on the lean side.
Bill
Re:Mercury '60's 400 & 500 fuel mix opinion 12 years 6 months ago #60574
  • Hugh Long
Thanks for all the replies. I think I will stay slightly on the heavy side also.
Time to create page: 0.156 seconds
We have 6729 guests and no members online
