TOPIC: Busted Mercontrol (need advice!)
Busted Mercontrol (need advice!) 12 years 4 months ago #64104
Hi All— While cruising around in my 1969 Glastron v142 SkiFlite (equipped with a 1967 Merc 500 50hp Thunderbolt Ignition), I pulled back on my controller and put it in neutral. At that point, it wouldn't shift any longer and my Mercontrol was jammed. All that to say, I completely busted my Mercontrol by man-handling it while identifying the problem with the engine (the shift cable came loose).
My question is: what is a decent/cheap compatible replacement for the MerControl? The Marine Shop is indicating that a new controller is upwards of $315, and I'd like to find a better price. Should I purchase a used Mercontrol or is it even worth it? Any help/advice is appreciated!
Michael
Re:Busted Mercontrol (need advice!) 12 years 4 months ago #64107
Welcome aboard Michael, good looking SkiFlite! If one of the gang here can't help with your control, there's always Ebay or Joe at www.FergusonPooleMarine.com . (Great guy with a magical knack for finding hard to source Merc stuff!)
Re:Busted Mercontrol (need advice!) 12 years 4 months ago #64115
  • g3jim
  • g3jim's Avatar
are you sure you are not having a shifting problem with the lower unit on your motor? That is what may be stuck.
Re:Busted Mercontrol (need advice!) 12 years 4 months ago #64116
That's what I originally thought as well, but the motor seems to be shifting fine by hand. I just busted the controller while figuring that out.
Re:Busted Mercontrol (need advice!) 12 years 4 months ago #64125
  • frog
  • frog's Avatar
  • Thank you received: 3
mbolzies. e-mail me, i have 3 extra controls, and i'll just send parts if that is what you want. or the complete unit. iam located in mn, so the shipping may be high. frog This email address is being protected from spambots. You need JavaScript enabled to view it.
Time to create page: 0.163 seconds
We have 8376 guests and one member online
