TOPIC: Even more prop questions!
Even more prop questions! 12 years 2 months ago #69640
Since this has been topic of choice lately, I need your help. Pick up a 19p 3 blade prop to try out something different for performance. The old 2 blade needs to retire to backup status. Plus I picked up this newer one for 30 bucks at an old supply shop.
I need to know if I need a thrust washer or something before I put the prop on the shaft? Its a newer prop and the rear is flat.
Also, is a 13"x19p too much pitch for a Mercury 650 on a 16' glasspar Avalon?
Here are some pics, tell me what you think.
Once again, thanks in advance.
Re:Even more prop questions! 12 years 2 months ago #69642
[img] [img]http://www.fiberglassics.com/media/kunena/attachments/legacy/images/2012_09_23_17-20120924-2.jpg
Re:Even more prop questions! 12 years 2 months ago #69643
Hi,
Yes, a different thrust hub with an additional spacer is utilized when installing the newer type propeller you have purchased.
Yes, I believe that you will find it to be too much pitch also. The newer propellers do not exchange pitch for pitch with the original propellers due to standard blade cupping and changes to the blade geometry. Also, the 1963-1969 Merc 650 used a smaller blade area series of propellers Mercury produced for them.
Regards,
Joe
www.fergusonpoolemarine.com
Profile Picture:
Re:Even more prop questions! 12 years 2 months ago #69671
Thanks Joe,
Based on my situation, what would you suggest? Pitch/diameter wise, or do you have reference to a kit I could use?
Re:Even more prop questions! 12 years 2 months ago #69805
Hi,
I responded to this by e-mail (you may have to check your Junk file).
I would be happy to try to answer your questions.
Regards,
Joe
Profile Picture:
Re:Even more prop questions! 12 years 1 month ago #70211
See my post in this thread. You have to be careful with the 4 hole 650, easy to over prop.
Geoff UK
Time to create page: 0.187 seconds
We have 6236 guests and no members online
