TOPIC: switch box weak spark 1981 50 hp
switch box weak spark 1981 50 hp 12 years 4 weeks ago #71065
  • otto
  • otto's Avatar Topic Author
:( I am testing out a 1981 50 hp merc on my 1960 glassmagic playmaster, turns over fine,good compression It does not fire, weak spark,I did ohms test on the coils, trigger circuit,and stator. I am leaning towards replacing the switch box but I want to make sure. how do you test this
I also have a 1968 50 hp merc, has 90 psi compression in #. , 1,2 cly. and only 60 psi in #3, cant fit the gauge down in there to test #4.also the e cable from the control is rotten. I may give up on this one for now ,the 1981 has more potential.
Re:switch box weak spark 1981 50 hp 12 years 3 weeks ago #71236
  • otto
:) I replaced the box and now i have a good spark
Re:switch box weak spark 1981 50 hp It smokes 12 years 3 weeks ago #71444
  • otto
testing out 1981 50 hp on a 1960 glassmagic playmaster special, custom royal, majestic queen of runabouts. it runs great with the new power pack. 45* a little cold out but I couldnt wait till next season. It smokes, exhaust gas coming out motor support hole below power head on the outside,could it be could it be a gasket or seal between the power head and driveshaft housing?
Re:switch box weak spark 1981 50 hp It smokes 12 years 3 weeks ago #71445
  • otto
We have 6303 guests and no members online
