TOPIC: Electronic ignition for a 165 mercruiser
Electronic ignition for a 165 mercruiser 9 years 10 months ago #104855
  • Jim L
  • Jim L's Avatar Topic Author
Ike got me to thinking about electronic ignitions and I spotted this on ebay. Anyone know of any pros or cons on this set up?? Will I have to have new wires,coil ?
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #104865
I've never heard of that brand before Jim, but know of numerous folks who swear by the Pertronix conversion kits;
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #104884
  • Ike
  • Ike's Avatar
  • Thank you received: 14
I am not familiar with that brand either but I am familiar with the Petronix. I have talked to a lot of people and it is very popular, and I even bought the kit. But then I changed my mind and swapped it for a new distributor with the electronic ignition built in. It cost more but I don't have to worry about the installation. You just pull out the old one and put in the new one and connected it to the coil.
PS: That looks exactly like the kit I had. If it works in a GM 250 (the merc 165) I suppose it would be ok. But, like you, I'd like to talk to someone who used it first.
Peter D. Eikenberry
newboatbuilders.com
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #105372
I successfully used a GM HEI distributor from a 6 6yl chevy truck on my mercruiser 165.
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #105381
  • Jim L
Dave,those gm hei ignitions are bullet proof. That might be the ticket. Should be able to find one of those at the Automotive Dismantling and Recycling Center (junkyard) :) . Thanks
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #105422
Thats what I did Jim. Don,t forget that the coil wire has a resistor in it so you cannot use it for 12V to the HEI. I don,t like extra wires laying around so I used the coil wire to energise a 12V relay that switches a good battery 12v to the hei. Also lets you shut down the engine completely with the ignition switch.
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #105434
  • Jim L
Dave, did you find a dist without a vacuum advance? I used to have a '72 chevy c 10 with a 350 and points dist I swapped the hei unit in for. Easy swap and well worth it.
Re:Electronic ignition for a 165 mercruiser 9 years 10 months ago #105437
I removed the vacuum advance and fixed(screwed) the advance plate down. Removed the centrifugal advance weights and springs too.
Time to create page: 0.174 seconds
We have 6490 guests and 2 members online
