TOPIC: Where does the water in the manifold go?
Where does the water in the manifold go? 13 years 1 day ago #53379
  • w guy
  • w guy's Avatar Topic Author
On a set up like this, what prevents the water from running into the head and through the open exhaust valves when the motor is turned off???
[img]http://[IMG]http://i83.photobucket.com/albums/j320/VerneFrantz/VLFPrivate/Motor.jpg[/img]
Re: Where does the water in the manifold go? 13 years 22 hours ago #53391
Those manifolds are water cooled.
They are not the same as a car manifold.
A water jacket surrounds the exhaust part of the manifold to keep it cool.
Warmed cooling water is injected into the exhaust ( motor running ) downstream of engine exhaust.
No danger of water going " uphill " when you shut the engine off.
Re:Where does the water in the manifold go? 13 years 21 hours ago #53394
there is one potential for water entering the cylinders thru the exhaust valves...if the engine deisels "runs backwards when shutoff"
the water gets sucked in the cylinder thats got the open exhaust valve...distinct possibility of hydro lock
you wont know till you attempt to start the motor and it wont turn over as the water in the cylinder cant be compressed
this happened to me 30 miles offshore, luckily I pulled the plugs turned the motor over to pump the water out and she fired back up
little rough for a few but all was well again
this is a very rare possibility
Re: Where does the water in the manifold go? 13 years 21 hours ago #53395
  • w guy
Thanks. I thought the whole log was full of water. I couldn't find a crossectional view to see that the exhaust was separate from the water until downstream. Sounds like something that should be pressure checked every so often to make sure the exhaust remains isolated from the water.
Verne :)
Re:Where does the water in the manifold go? 9 years 11 months ago #104332
  • Ike
  • Ike's Avatar
  • Thank you received: 14
Check your oil. If water is leaking out of the manifold into the cylinders the oil will be milky. If it is get it fixed immediately.
Peter D. Eikenberry
newboatbuilders.com
Time to create page: 0.170 seconds
We have 6230 guests and no members online
