TOPIC: Rebuilding my Holsclaw
Rebuilding my Holsclaw 13 years 2 months ago #46075
  • FANTM58
  • FANTM58's Avatar Topic Author
OK I tore her all down, fix a few shaddy additions made by the previous owner.i added a spare tire mount, ordered all new rollers.
It all went to the powder coaters this morning !!
Will be needing new tires and zi will be doing sometihing differ4ent
with the tail lights.Think I will mount them to the vert roller arms,Better visability and keep them dry !!
I upgraded the reciever to a 2" now all my toys have the same Ball.
I am doing it all in red to match the boat`s upper !
I am looking for some baby moons ,and white walls,I mat have to make my own !!12" tires not much of a choice out there ??
Re:Rebuilding my Holsclaw 13 years 2 months ago #46078
Powder coat would be nice. How much will that set you back? I just did my TeeNee with Rustoleum.
Re:Rebuilding my Holsclaw 13 years 2 months ago #46079
  • FANTM58
I do a lot of work with a company for work, so he does me right!!!
I have never had to pay for any of my personal projects with them !!
So,,,,, The price is right,,,and I do not have to strip it down,They do all the sand blasting..
When I get everything back I will post some pics of the reassembly !!
Your trailer is looking good--a-lot of work !!
Re:Rebuilding my Holsclaw 13 years 2 months ago #46093
That's sweet.
Without the fenders you can't see the effect. :woohoo:
Re:Rebuilding my Holsclaw 13 years 2 months ago #46107
Interesting Holsclaw, FANTM, don't know that I've seen one configured quite like that. The folding tongue part must have been added by a previous owner? Peter Crowl (in Denver) had some of the moon hubcaps, don't know if he has any left or not. We've got the part number for Monroe Magnum replacement shocks back in the archives here somewhere if you need it, just holler. Can't wait to see it when the powder coating is done. I think I would do the fenders (and maybe the winch stand) in white, but that's just my opinion. I'm sure it will look great either way. ;)
I agree, Robert's trailer turned out really nice!
Re:Rebuilding my Holsclaw 13 years 2 months ago #46269
  • FANTM58
The folding tongue was an add on that I removed,,,,Really crappy work.I`m surprised it made it home ??The welds were all cracked and it was brazed not welded !!I reinstealled the solid design.
I was kicking around the options of white accents..But since I am getting free powder coating,,I did not want to push my luck by addind too many differten steps.So it is going all red too match the boat,,,with white walls and moons it should turn out pretty cool !
Re:Rebuilding my Holsclaw 13 years 2 months ago #46316
Carlisle makes some pretty good 12" trailer tires. Haven't seen any white walls though.
Re:Rebuilding my Holsclaw 13 years 2 months ago #46318
  • FANTM58
I want to replace the rope in my winch.Is there any special type or strength I need to use,,,I want to find red rope if possible ??
Re:Rebuilding my Holsclaw 13 years 2 months ago #46327
fantm,if you could get 13 inch rims for your trailer here is a place for 13 inch white wall tires,they are firestone ,
www.widewhitetires.com/firestone.html ..and walmart sells winch straps cheap if it would work for you,john
Re:Rebuilding my Holsclaw 13 years 2 months ago #46334
If your winch can take a strap, do that. Straps wear longer and just look neater. If you're sold on rope, any kind of poly rope that has capacity for what your rig weighs will do the trick.
All this talk about white walls is interesting. First thing I look for in tires is if they're made for a trailer, then I want radials. I have never seen radial trailer tires with white walls, but that doesn't mean they're not made. You can always add white walls to any tire you get, check out the porta walls here: www.portawalls.com/
Good luck!
Re:Rebuilding my Holsclaw 13 years 2 months ago #48003
  • FANTM58
OK a little progress, I cleaned and painted all the hardware, to match the trailer,,,when I get it back ??
I bought a set of used 12" tires, almost new 155 sr 12`s for cheap.
I will be painting white walls on them today.And I will try to secure a strap type hook to my rope winch..
Re:Rebuilding my Holsclaw 13 years 1 month ago #48367
  • FANTM58
OK update ....
I picked up the parts from the powder coaters yesterday,And dropped off my 2 gas tanks and a spare rim to coat as well.
Last nite I started to reassemble the trailer..No surprises yet ???
Re:Rebuilding my Holsclaw 13 years 1 month ago #48373
looks great, I like the assembly part of the job with all new clean painted parts.
I got the original Holsclaw hubcaps for mine, 3 of them newly powder coated...Im done
Re:Rebuilding my Holsclaw 13 years 1 month ago #48378
Looks like a shinny new "Build you own Holsclaw" kit, SWEET!
Re:Rebuilding my Holsclaw 13 years 1 month ago #48379
I'm still trying to figure out how to get the original pins out of the rollers. Nothing I've tried so far works, and I need to get it figured out soon!
Re:Rebuilding my Holsclaw 13 years 1 month ago #48382
Are you talking about the bunk rollers, Frank? One end looks like a carriage bolt head (rounded), and the other is like a rivet peened over all around? Drilling the peen off is the only solution I can come up with on those.
I'm putting off replacing all the rollers on my Holsclaw because they're weird sizes, (keel rollers especially), and many of the shafts would have to be replaced in the procedure mentioned above.
Anybody got a trick to rejuvenate old rubber rollers so they don't mar the hull?
(Sorry about jumping your thread, Fantm!)
Re:Rebuilding my Holsclaw 13 years 1 month ago #48396
Yes Mark, the bunk rollers. I guess I need a bigger drill bit. I tried one that I thought might be too big, and it didn't work. I'll get back at it soon. Thanks!
Re:Rebuilding my Holsclaw 13 years 1 month ago #48504
  • FANTM58
I was able the drive them all out !!
I bought all new rollers. Most are not the same size , but I will make them work !! I will post updates on that portion of the rebuild !!
A few more pictures of some progress last nite > WOW my dog looks posessed in that last picture !@#$
Re:Rebuilding my Holsclaw 13 years 1 month ago #48511
He sure does! Better be nice to him and treat him right. :laugh:
Coming along great Fantm, will be watching for your updates. Please pass along the size (and source) on the rollers you use, I think it would be helpful to many of us.
Re:Rebuilding my Holsclaw 13 years 1 month ago #48527
I heated mine and drove them out with hammer and round chisel
Re:Rebuilding my Holsclaw 13 years 1 month ago #48585
That red sure comes right out of the picture and grabs ya. :woohoo:
Re:Rebuilding my Holsclaw 13 years 1 month ago #48722
  • FANTM58
As far as the source I will have to look it up ?
For the Keel rollers, I bought some that require some modifications.
I need to sand about .25" off and replace the shaft with a .5" bar
and secure them with thoes little "hat" caps
As far as the other rollers, I am considering using boards for the sides instead of the original rollers.
the rear roller will work , I just need to replace the shaft with a 5/8" bar.
Re:Rebuilding my Holsclaw 13 years 1 month ago #48730
its looking great,i have a holsclaw and might replce the old hard rollers with bunks.nice job fantm!,john
Re:Rebuilding my Holsclaw 13 years 1 month ago #48813
I had the same roller I used to replace one on my Electra trailer years ago. I had to sand it down also.
Re:Rebuilding my Holsclaw 13 years 1 month ago #48925
  • FANTM58
Mad prop
Mabel some pictures would help ?
I need to see something to really get my mind around it .
Re:Rebuilding my Holsclaw 13 years 1 month ago #48953
FANTM58 wrote:
Mad prop
Im guessing that mine was taken apart before I got it as I dont see what the difficulty is ....I removed the cotter pins and drifted the pins out no problem
Re:Rebuilding my Holsclaw 13 years 1 month ago #49013
  • FANTM58
Sorry mad Prop I meant to address that one to Frank !!
Re:Rebuilding my Holsclaw 13 years 1 month ago #49066
Holsclaw bunk rollers; (Each on a 4' "rail)
You can't really see them as well as I had hoped, I think they're a little different that what yours has on it Fantm. The keel rollers have the cotter pins and or cap nuts, as MP described, but these are "peened" (for lack of a better word) at the factory (top pic).
Re:Rebuilding my Holsclaw 13 years 1 month ago #49075
  • FANTM58
They do appear different than mine .cant quite tell from pics ,but drill and grinder ?
Re:Rebuilding my Holsclaw 13 years 1 month ago #49387
  • FANTM58
I got an early X-Mass gift yesterday !!
My baby moon`s showed up.....and they fit !!!
bought them off E-Bay $35.00 for a set of 4
last nite I was sanding down the rollers to fit between the frame
when my sander motor burned up !@#$%
But it did last 30 yrs ?
heading to grainger to find a replacement motor .
Re:Rebuilding my Holsclaw 13 years 1 month ago #49412
That is a nice looking set og wheels and tires.
Re:Rebuilding my Holsclaw 13 years 1 month ago #49414
  • Shelby18
  • Shelby18's Avatar
That is a fantastic looking set-up. I hope my Hilltop looks half that good when it is done.
Great to be on board.
Rick
Re:Rebuilding my Holsclaw 13 years 1 month ago #49447
  • FANTM58
Thanks guys,,I think the trailer will look better than the boat !
Re:Rebuilding my Holsclaw 12 years 11 months ago #54531
  • FANTM58
OK I got some work done this weekend,I installed my bunkboars on my roller brakets.
I have a few pictures of the precedure,if anyone is interested.
Or if someone has concerns, please let me know..
Re:Rebuilding my Holsclaw 12 years 11 months ago #54544
Really sharp looking job you have done there. I like how you mounted your bunks, really looks first class and should last for years. Nice color also, just kinda jumps out and grabs you. Keep up the good work and keep us posted. Skip.
Re:Rebuilding my Holsclaw 12 years 11 months ago #54548
Really nice work Fantm, looks great. Did you fabricate those bunk board brackets (the black part)? I like the way they turned out, at any rate!
Re:Rebuilding my Holsclaw 12 years 11 months ago #54552
  • FANTM58
Thanks guys,
And yes I used 4x4x.25" plates and some old shelving legs.I
drilled 2 .25" holes over the tubing and then mig welded then in.
Time to create page: 0.337 seconds
We have 7344 guests and no members online
